BackgroundColor Property
The BackgroundColor property contains the color of the background of the animated image.
    document.all["id_name"].BackgroundColor [=color]
    ColorValue that specifies or retrieves the background color.
    If the transparent property is set to true the background color specifies the color value that will appear transparent. Thus, all pixels of the source-image that are assigned this background color will become transparent.
    ColorValue: An RGB (Red, Green, Blue) 32-bit color value that defines a solid color. Each of the Red, Green, Blue portions represents the color intensity between 0 and 255 (or 0x00 to 0xff hexadecimal). The RGB color value can be calculated: ColorValue = Red + Green*256 + Blue*65536. Please note that this representation differs from HTML color values which are hexadecimal RRGGBB.
    The following example reads the BackgroundColor property and shows it in an alert window.
    margin-top:5px; "
    	"skins\default\img\anilogo.png">
    	<PARAM NAME="TimerInterval" VALUE="25">
    function id_SKAnimateControl::Click()
    	alert(document.all["id_SKAnimateControl"].BackgroundColor);
