ImageFile Property
The ImageFile property contains the absolute or relative path to the animation's source image.
    document.all["id_name"].ImageFile [=String]
    String that specifies or retrieves the path to the image file.
    The specified path must be either absolute or relative to SiteKiosk's installation directory. If this property is set, the animation image will be reloaded immediately.
    The following example reads the ImageFile property and shows it in an alert window.
    function changeAnimation()
    	var path1="skins\\default\\img\\buttonbar.png";
    	var path2="skins\\default\\img\\anilogo.png";
    	if(document.all["id_SKAnimateControl"].ImageFile==path1)
    	document.all["id_SKAnimateControl"].ImageFile=path2;
    	else document.all["id_SKAnimateControl"].ImageFile=path1;
    <div onclick="changeAnimation()">Change Animation!</div>
    margin-top:5px; "
    	"skins\default\img\buttonbar.png">
    	<PARAM NAME="TimerInterval" VALUE="100">
    function id_SKAnimateControl::Click()
    function id_SKAnimateControl::DblClick()
    	document.all["id_ImageCounter"].innerHTML=0;
