ImageWidth Property
The ImageWidth property contains the width of a single animation image.
    document.all["id_name"].ImageWidth [=long]
    Long value that specifies or retrieves the width of the image.
    The ImageWidth property must be set to the width of a single animation frame to be able to play back the animation correctly. It indirectly defines how many frames an animation contains. If a new animation with a different frame width is loaded, it will be necessary to update the ImageWidth value - otherwise the animation will look corrupted.
    The following example reads the ImageWidth property and shows it in an alert window.
    margin-top:5px; "
    	"skins\default\img\anilogo.png">
    	<PARAM NAME="TimerInterval" VALUE="25">
    function id_SKAnimateControl::Click()
       alert(document.all["id_SKAnimateControl"].ImageWidth);
