Reset Method
The Reset method resets the animation to start position.
document.all["id_name"].Reset()
Use the Reset method to go back to the start position of the animated image. Otherwise the animation will start at the current position, e.g. where it was stopped by means of the Stop method.
The following example uses the Start, Stop and Reset methods of the SKAnimateControl ActiveX control. Note that the path of the image is absolute in relation to the SiteKiosk folder.
function startAnim()
function stopAnim()
function resetAnim()
margin-top:5px; "
"skins\default\img\anilogo.png">
<PARAM NAME="TimerInterval" VALUE="25">
<div onclick="startAnim()">ClickStart!</div>
<div onclick="stopAnim()">ClickStop!</div>
<div onclick="resetAnim()">ClickReset!</div>
