SrcAlpha Property
The SrcAlpha property contains the overall transparency of the animation control.
document.all["id_name"].SrcAlpha [=byte]
Byte value that specifies or retrieves the alpha channel value.
PossibleValues: 0-255
If you set SrcAlpha to 0, the animation will be invisible because of the fact that it is completely transparent. Set the SrcAlpha value to 255 to draw opaque images.
Not available on Window95.
The following example increases the alpha value by 10 on each click on the div area. The start value is 0, which causes the image to slowly appear on the screen.
function changeAlpha()
document.all["id_SKAnimateControl"].SrcAlpha=
document.all["id_SKAnimateControl"].SrcAlpha + 10;
<div onclick="changeAlpha()">Change Alpha!</div>
<OBJECT id="id_SKAnimateControl" style="width:65px;
height:65px; border-width:0px; margin-right:0px; margin-bottom:5px;
margin-top:5px; "
"skins\default\img\buttonbar.png">
<PARAM NAME="TimerInterval" VALUE="100">
<PARAM NAME="UseAlpha" VALUE="1">
function id_SKAnimateControl::Click()
function id_SKAnimateControl::DblClick()
document.all["id_ImageCounter"].innerHTML=0;
