Start Method
The Start method starts an animated image.
document.all["id_name"].Start()
Once the animation is started it will only stop when you are applying the Stop method.
The following example uses the Start, Stop and Reset methods of the SKAnimateControl ActiveX control. Note that the path to the image is absolute in relation to the SiteKiosk folder.
function startAnim()
function stopAnim()
function resetAnim()
margin-top:5px; "
"skins\default\img\anilogo.png">
<PARAM NAME="TimerInterval" VALUE="25">
<div onclick="startAnim()">ClickStart!</div>
<div onclick="stopAnim()">ClickStop!</div>
<div onclick="resetAnim()">ClickReset!</div>
