Stop Method
The Stop method stops the animation of an animated image.
document.all["id_name"].Stop()
The Stop method will stop the image at the current position. To go back to the start of the animated image, you will have to use the Reset method.
The following example uses the Start, Stop and Reset methods of the SKAnimateControl ActiveX control. Note that the path to the image is absolute in relation to the SiteKiosk folder.
function startAnim()
function stopAnim()
function resetAnim()
margin-top:5px; "
"skins\default\img\anilogo.png">
<PARAM NAME="TimerInterval" VALUE="25">
<div onclick="startAnim()">ClickStart!</div>
<div onclick="stopAnim()">ClickStop!</div>
<div onclick="resetAnim()">ClickReset!</div>
