TimerInterval Property
The TimerInterval property contains the delay between two animation frames in milliseconds.
document.all["id_name"].TimerInterval [=long]
Long value that specifies the time a single frame is displayed.
If you would like to play an animation at a certain frame rate you can simply calculate the TimerInterval as follows: TimerInterval = 1000/FramesPerSecond.
The following example shows an animation with a specified timing.
function startAnim()
function stopAnim()
function resetAnim()
margin-top:5px; "
"skins\default\img\anilogo.png">
<PARAM NAME="TimerInterval" VALUE="25">
<div onclick="startAnim()">ClickStart!</div>
<div onclick="stopAnim()">ClickStop!</div>
<div onclick="resetAnim()">ClickReset!</div>
