Transparent Property
The Transparent property indicates if transparency is to be used for the animated image.
document.all["id_name"].Transparent [=boolean]
Boolean value. True if transparency is to be used.
False if no transparency is to be used.
The following example shows an animation deploying transparency.
function startAnim()
function stopAnim()
function resetAnim()
margin-top:5px; "
"skins\default\img\anilogo.png">
<PARAM NAME="TimerInterval" VALUE="25">
<PARAM NAME="Transparent" VALUE="1">
<div onclick="startAnim()">ClickStart!</div>
<div onclick="stopAnim()">ClickStop!</div>
<div onclick="resetAnim()">ClickReset!</div>
