UseAlpha Property
The UseAlpha property states if alpha channel is to be used for the animation.
    document.all["id_name"].UseAlpha [=boolean]
    Boolean value. True if an alpha channel is to be used.
    False if no alpha channel is to be used.
    The following example turns the UseAlpha property on or off after a mouse click on the div area.
    function changeAlpha()
    	if(document.all["id_SKAnimateControl"].UseAlpha == true)
    	document.all["id_SKAnimateControl"].UseAlpha = false
    	else document.all["id_SKAnimateControl"].UseAlpha = true;
    <div onclick="changeAlpha()">Change Alpha!</div>
    <OBJECT id="id_SKAnimateControl" style="width:65px;
    height:65px; border-width:0px; margin-right:0px; margin-bottom:5px;
    margin-top:5px; "
    	"skins\default\img\buttonbar.png">
    	<PARAM NAME="TimerInterval" VALUE="100">
    	<PARAM NAME="UseAlpha" VALUE="1">
    	<PARAM NAME="SrcAlpha" VALUE="25">
    function id_SKAnimateControl::Click()
    function id_SKAnimateControl::DblClick()
    	document.all["id_ImageCounter"].innerHTML=0;
