DrawMode Property
The DrawMode property contains the draw mode.
document.all["id_name"].DrawMode [=long]
Long value that specifies or retrieves the draw mode.
This property can be used instead of the Opened, Small and Selected property. The following values can be combined using the | operator:
Selected = 65536
Small = 1
Opened = 2
The following example shows the DrawMode property when the link is clicked.
function ShowProp()
alert(SKFileIcon.DrawMode);
<OBJECT ID="SKFileIcon" width="16" height="16"
CLASSID="CLSID:802B4DFC-E0AD-40DC-BFC2-EF5CB99E1291">
<PARAM NAME="DrawMode" value="2">
<PARAM NAME="Text" VALUE="Optional text">
<PARAM NAME="Path" VALUE="c:\programs\sitekiosk\sitekiosk.exe">
<a href="javascript:ShowProp()">Show DrawMode property</a>
