Opened Property
The Opened property indicates if the opened icon is drawn.
    document.all["id_name"].Opened [=bool]
    Boolean value that specifies or retrieves whether the
    The following example shows the Opened property when the link is clicked.
    function ShowProp()
       alert(SKFileIcon.Opened);
    <OBJECT ID="SKFileIcon" width="16" height="16"
    CLASSID="CLSID:802B4DFC-E0AD-40DC-BFC2-EF5CB99E1291">
      <PARAM NAME="Text" VALUE="Optional text">
      <PARAM NAME="Path" VALUE="c:\programs\sitekiosk\sitekiosk.exe">
      <PARAM NAME="Small" VALUE="0">
      <PARAM NAME="Opened" VALUE="1">
      <PARAM NAME="Selected" VALUE="0">
    <a href="javascript:ShowProp()">Show Opened property</a>
