Path Property
The Path property contains the full path of the icon file.
document.all["id_name"].Path [=string]
String that specifies or retrieves the full path.
The icon file format can be .exe or .ico.
The following example shows the Path property when the link is clicked.
function ShowProp()
alert(SKFileIcon.Path);
<OBJECT ID="SKFileIcon" width="16" height="16"
CLASSID="CLSID:802B4DFC-E0AD-40DC-BFC2-EF5CB99E1291">
<PARAM NAME="Text" VALUE="Optional text">
<PARAM NAME="Path" VALUE="c:\programs\sitekiosk\sitekiosk.exe">
<PARAM NAME="Small" VALUE="0">
<PARAM NAME="Opened" VALUE="1">
<PARAM NAME="Selected" VALUE="0">
<a href="javascript:ShowProp()">Show Path property</a>
