Selected Property
The Selected property indicates if the selected icon is drawn.
document.all["id_name"].Selected [=bool]
Boolean value that specifies or retrieves whether the selected icon is drawn.
The following example shows the Selected property when the link is clicked.
function ShowProp()
alert(SKFileIcon.Selected);
<OBJECT ID="SKFileIcon" width="16" height="16"
CLASSID="CLSID:802B4DFC-E0AD-40DC-BFC2-EF5CB99E1291">
<PARAM NAME="Text" VALUE="Optional text">
<PARAM NAME="Path" VALUE="c:\programs\sitekiosk\sitekiosk.exe">
<PARAM NAME="Small" VALUE="0">
<PARAM NAME="Opened" VALUE="1">
<PARAM NAME="Selected" VALUE="0">
<a href="javascript:ShowProp()">Show Selected property</a>
