ClientHeight Property
The ClientHeight property contains the height of the client area inside the dialog window.
    [long=] SKHtmlDialog.ClientHeight
    Long value that retrieves the height.
    The following example creates and shows a dialog and displays the height of the client area in an alert window.
    mydialog.Width = 400;
    mydialog.Height = 400;
    mydialog.Title = true;
    alert(mydialog.ClientHeight);
