ClientTop Property
The ClientTop property contains the vertical position of the client area inside the dialog window.
[long=] SKHtmlDialog.ClientTop
Long value that retrieves the position.
The following example creates and shows a dialog and displays the vertical position of the client area in an alert window.
mydialog.Title = true;
alert(mydialog.ClientTop);
