ClientWidth Property
The ClientWidth property contains the width of the client area inside the dialog window.
[long=] SKHtmlDialog.ClientWidth
Long value that retrieves the width.
The following example creates and shows a dialog and displays the width of the client area in an alert window.
mydialog.Width = 400;
mydialog.Height = 400;
mydialog.Title = true;
alert(mydialog.ClientWidth);
