Closable Property
The Closable property indicates if the dialog window can be closed.
SKHtmlDialog.Closable [=bool]
Boolean value that specifies or retrieves if the dialog can be closed or not.
If this property is false, the dialog can not be closed by the user even if the sysmenu property is true.
But it can be closed from within a script using the CloseDialog method.
The following example creates a dialog that cannot be closed.
mydialog.Title = true;
mydialog.Sysmenu = true;
mydialog.Closable = false;
