CloseOnInput Property
The CloseOnInput property indicates if the dialog is to be closed on any mouse click or keyboard input.
SKHtmlDialog.CloseOnInput [=bool]
Boolean value that specifies or retrieves if the dialog is to be closed on input or not.
The following example creates a dialog that will be closed directly after a mouse click or keyboard input has been noticed.
mydialog.CloseOnInput = true;
