DragData Property
The DragData property contains the name of files dragged into the browser window.
    [str=] SKHtmlDialog.DragData
    String that retrieves the drag data.
    The following example shows the drag data in an alert window.
    mydialog.Title = true;
    alert(mydialog.DragData);
