DrawMenuBar Method
The DrawMenuBar method draws the menu bar.
    SKHtmlDialog.DrawMenuBar()
    The following example creates a dialog with a menu bar and redraws the menu directly after showing it.
       switch (ai_CommandID)
          case 3: alert('Bye'); break;
    mydialog.Title = true;
    mydialog.DrawMenuBar();
