FlashWindow Method
The FlashWindow method flashes the dialog window.
SKHtmlDialog.FlashWindow(flags, count, timeout)
flags |
DWORD value that contains the flags. |
count |
DWORD value that contains the number of flashes. |
timeout |
DWORD value that contains the milliseconds between the flashes. |
Possible flags are:
0 : stop
1 : caption
2 : tray
1|2 : all
4 : timer
12 : timernofg
See FLASHWINFO (MSDN) for further information.
The following example flashes a dialog window 3 times.
mydialog.Title = true;
mydialog.FlashWindow(1, 3, 1000);
