Foreground Property
The Foreground property indicates if the dialog is in the foreground.
[bool=] SKHtmlDialog.Foreground
Boolean value that retrieves the foreground status.
The following example determines if the dialog is in the foreground and shows it in an alert window.
<a href="alert(mydialog.Foreground)">show foreground status<a>
