Handle Property
The Handle property contains the window handle of the dialog.
    [long=] SKHtmlDialog.Handle
    Long value that retrieves the handle of the window.
    The following example creates a dialog and shows its window handle.
    alert("Window handle: " + mydialog.Handle);
