IsWindow Property
The IsWindow property indicates whether the dialog is a window.
[bool=] SKHtmlDialog.IsWindow
Boolean value that retrieves the window status.
The following example determines if the dialog is a window and shows it in an alert window.
alert(mydialog.IsWindow);
