Left Property
The Left property contains the horizontal position of the dialog window.
    SKHtmlDialog.Left [=long]
    Long value that specifies or retrieves the position.
    The following example creates a dialog and displays it at the position 100, 100.
    mydialog.Height = 150;
    mydialog.Title = true;
    mydialog.Left = 100;
    mydialog.Top = 100;
