Maximized Property
The Maximized property indicates if the dialog is maximized.
    [bool=] SKHtmlDialog.Maximized
    Boolean value that retrieves the maximized status.
    The following example determines if the dialog is maximized and shows it in an alert window.
    <a href="alert(mydialog.Maximized)">show maximized status<a>
