Menu Property
The Menu property contains the handle of the used menu.
    SKHtmlDialog.Menu [=long]
    Long value that specifies or retrieves the menu handle.
    Set this property to 0 to remove the menu from the dialog.
    The following example creates a HTML dialog containing a menu with submenus.
       switch (ai_CommandID)
          case 3: alert('Bye'); break;
    mydialog.Title = true;
