MinHeight Property
The MinHeight property contains the minimum height of the dialog window.
    SKHtmlDialog.MinHeight [=long]
    Long value that specifies or retrieves the minimum height.
    The following example creates a dialog with a minimum height of 400 pixel.
    mydialog.Title = true;
    mydialog.Width = 500;
    mydialog.Height = 500;
    mydialog.MinHeight = 400;
