Minimized Property
The Minimized property indicates if the dialog is minimized.
[bool=] SKHtmlDialog.Minimized
Boolean value that retrieves the minimized status.
The following example determines if the dialog is minimized and shows it in an alert window.
<a href="alert(mydialog.Minimized)">show minimized status<a>
