MinWidth Property
The MinWidth property contains the minimum width of the dialog window.
    SKHtmlDialog.MinWidth [=long]
    Long value that specifies or retrieves the minimum width.
    The following example creates a dialog with a minimum width of 400 pixel.
    mydialog.Title = true;
    mydialog.Width = 500;
    mydialog.MinWidth = 400;
    mydialog.Height = 500;
