OnClose Event
Fires when the dialog is closed.
    SKHtmlDialog.OnClose = handler
    The following example shows an alert window when the dialog is closed.
    function onClose()
       alert('Dialog is closed');
    mydialog.Title = true;
    mydialog.OnClose = onClose;
