OnCommand Event
Fires when a menu entry has been clicked.
SKHtmlDialog.OnCommand = handler
code |
Long value that contains the code. |
cmdID |
Long value that contains the ID of the clicked item. |
handle |
Handle to the menu. |
The following example creates a HTML dialog containing a menu with submenus.
function onCommand(code, cmdID, handle)
switch (cmdID)
case 3: alert('Bye'); break;
mydialog.Title = true;
