Parent Property
The Parent property contains the parent window of the dialog.
    SKHtmlDialog.Parent [=long]
    Long value that specifies or retrieves the parent
    window handler.
    The following example creates a dialog and sets the active window to be its parent.
    activewindow = SiteKiosk.WindowList.ActiveWindow;
    mydialog.Parent = activewindow.Handle;
