PreventInput Property
The PreventInput property indicates if input is allowed or not.
SKHtmlDialog.PreventInput [=bool]
Boolean value that specifies or retrieves if input is allowed or not.
If input is prevented the user will not be able to leave the dialog window or put anything in.
The following example creates a dialog which prevents input.
mydialog.PreventInput = true;
