Region Property
The Region property contains the handle of the dialog region.
    SKHtmlDialog.Region [=long]
    Long value that specifies or retrieves the handle of
    the region.
    The following example creates a dialog with a region that creates round corners.
    mydialog.URL = "http://www.sitekiosk.com";
    mydialog.Title = true;
    dlgw = mydialog.Width;
    dlgh = mydialog.Height;
    myregion = SiteKiosk.SiteKioskUI.CreateRegion();
    myregion.AddRoundRect(0, 0, dlgw, dlgh, 12, 12, "am");
    mydialog.Region = myregion.Handle;
