ScrollBars Property
The ScrollBars property indicates if the dialog contains scrollbars.
    SKHtmlDialog.ScrollBars [=bool]
    Boolean value that specifies or retrieves if
    scrollbars should be used or not.
    The following example creates a dialog with scrollbars and shows it.
    mydialog.ScrollBars = true;
