SetPosition Method
The SetPosition method sets the position and size of the dialog.
    SKHtmlDialog.SetPosition(left, top, width, height)
    left Long value that specifies the horizontal position.
    top Long value that specifies the vertical position.
    width Long value that specifies the width.
    height Long value that specifies the height.
    The position and size can be set before or after showing the dialog.
    The following example creates a dialog and sets its size and position.
    mydialog.Title = true;
    mydialog.SetPosition(100, 100, 400, 200);
