Styles Property
The Styles property contains the window styles of the dialog.
    SKHtmlDialog.Styles [=dword]
    DWORD value that specifies or retrieves the styles.
    Please note that Javascript in IE9 cannot handle the hexadecimal values any longer and you need to use the decimal values. If you need to create a dialog that uses more than one value you have to do the Or-function with the help of a calculator.
    Possible window styles are:
    WS_OVERLAPPED = 0 (= 0x00000000)
    WS_POPUP = 2147483648 (= 0x80000000)
    WS_CHILD = 1073741824 (= 0x40000000)
    WS_MINIMIZE = 536870912 (= 0x20000000)
    WS_VISIBLE = 268435456 (= 0x10000000)
    WS_DISABLED = 134217728 (= 0x08000000)
    WS_CLIPSIBLINGS = 67108864 (= 0x04000000)
    WS_CLIPCHILDREN = 33554432 (= 0x02000000)
    WS_MAXIMIZE = 16777216 (= 0x01000000)
    WS_CAPTION = 12582912 (= WS_BORDER | WS_DLGFRAME)
    WS_BORDER = 8388608 (= 0x00800000)
    WS_DLGFRAME = 4194304 (= 0x00400000)
    WS_VSCROLL = 2097152 (= 0x00200000)
    WS_HSCROLL = 1048576 (= 0x00100000)
    WS_SYSMENU = 524288 (= 0x00080000)
    WS_THICKFRAME = 262144 (= 0x00040000)
    WS_GROUP = 131072 (= 0x00020000)
    WS_TABSTOP = 65536 (= 0x00010000)
    WS_MINIMIZEBOX = 131072 (= 0x00020000)
    WS_MAXIMIZEBOX = 65536 (= 0x00010000)
    WS_TILED = WS_OVERLAPPED
    WS_ICONIC = WS_MINIMIZE
    WS_SIZEBOX = WS_THICKFRAME
    WS_TILEDWINDOW = WS_OVERLAPPEDWINDOW
    WS_OVERLAPPEDWINDOW = 13565952 (= WS_OVERLAPPED | WS_CAPTION | WS_SYSMENU | WS_THICKFRAME | WS_MINIMIZEBOX | WS_MAXIMIZEBOX)
    WS_POPUPWINDOW = 2156396544 (= WS_POPUP | WS_BORDER | WS_SYSMENU)
    WS_CHILDWINDOW = WS_CHILD
    See Window Styles (MSDN) for further information.
    The following example uses the Style property to create a dialog with title bar and border.
    var MY_WND_STYLE = 12582912; //WS_OVERLAPPED | WS_CAPTION
    mydialog.Styles = MY_WND_STYLE;
