Sysmenu Property
The Sysmenu property indicates if the dialog window has a standard window menu.
SKHtmlDialog.Sysmenu [=bool]
Boolean value that specifies or retrieves if a menu exists.
The standard window menu contains a close button and move functionality.
Even if the menu is hidden, user will be able to close the window by pressing Esc.
The following example creates a dialog which the user can close.
mydialog.Sysmenu = true;
