Top Property
The Top property contains the vertical position of the dialog window.
Long value that specifies or retrieves the position.
The following example creates a dialog and displays it at the position 100, 100.
mydialog.Height = 150;
mydialog.Title = true;
mydialog.Left = 100;
mydialog.Top = 100;
