TopMostWindow Property
The TopMostWindow property indicates if the dialog window is to be displayed on top of other windows.
    SKHtmlDialog.TopMostWindow [=bool]
    Boolean value that specifies or retrieves if the
    dialog box overlaps other windows.
    If this property is true other dialog boxes will not cover this one. To use this, define the parent property of the dialog box.
    The following example creates a dialog box that cannot be covered by other windows.
    activewindow = SiteKiosk.WindowList.ActiveWindow;
    mydialog.Title = true;
    mydialog.Parent = activewindow.Handle;
    mydialog.TopMostWindow = true;
