Transparency Property
The Transparency property contains the transparency of the dialog window.
SKHtmlDialog.Transparency [=long]
Long value that specifies or retrieves the transparency.
Possible values:
0 (invisible) - 255 (solid)
The following example creates a transparent dialog.
mydialog.Title = true;
mydialog.Transparency = 100;
