Visible Property
The Visible property indicates whether the dialog is visible.
    SKHtmlDialog.Visible [=bool]
    Boolean value that specifies or retrieves the visibility.
    The following example determines the visibility of an existing dialog and shows it in an alert window.
    alert(mydialog.Visible);
