DefaultItem Property
The DefaultItem property contains the command ID of the bold written default menu item.
SKMenu.DefaultItem [=cmdID]
UINT value that specifies or retrieves the command ID of the default item.
The following example creates a HTML dialog containing a menu and specifies the first entry as the default item.
switch (ai_CommandID)
case 3: alert('Bye'); break;
mySubMenu.DefaultItem = 1;
mydialog.Title = true;
