GetChecked Method
The GetChecked method determines whether an item is checked.
    [bool=] SKMenu.GetChecked(commandID)
    commandID UINT value that contains the command ID of the item.
    Returns a Boolean value that indicates if the item is checked.
    The following example creates a HTML dialog containing a menu with submenus, an item can be checked and unchecked.
       switch (ai_CommandID)
          case 1:
            alert(mySubMenu.GetChecked(1));
            break;
          case 3:
            mySubMenu.SetChecked(1, !mySubMenu.GetChecked(1));
            break;
    mySubMenu.InsertString(3,1, "Say if ckecked", "");
    mySubMenu.InsertString(4,3, "Check/Uncheck previous item", "");
    myMenu.InsertSubmenu(2,4, mySubMenu.Handle, "Menu", "");
    mydialog.Title = true;
