GetDisabled Method
The GetDisabled method determines whether an item is disabled.
    [bool=] SKMenu.GetDisabled(commandID)
    commandID UINT value that contains the command ID of the item.
    Returns a Boolean value that indicates if the item is disabled.
    The following example creates a HTML dialog containing a menu with submenus, an item can be disabled and enabled.
       switch (ai_CommandID)
          case 1:
            alert('Item 1');
            break;
          case 3:
            mySubMenu.SetDisabled(1, !mySubMenu.GetDisabled(1));
            break;
    mySubMenu.InsertString(3,1, "Say Item 1", "");
    mySubMenu.InsertString(4,3, "Enable/Disable Item 1", "");
    mydialog.Title = true;
