InsertString Method
The InsertString method inserts an item into the menu.
    SKMenu.InsertString(beforeID, commandID, string, image)
    beforeID UINT value that contains the command ID of the following item.
    commandID UINT value that contains the command ID of the new item.
    string String that contains the text of the new item.
    image String that contains the absolute path of an image to show on the left side of the new item.
    The following example creates a HTML dialog containing a menu with submenus.
       switch (ai_CommandID)
          case 3: alert('Bye'); break;
    mydialog.Title = true;
