RemoveItem Method
The RemoveItem method removes an item from the menu.
SKMenu.RemoveItem(commandID)
commandID |
UINT value that contains the command ID of the item. |
The following example creates a HTML dialog containing a menu with submenus, an item can be removed.
switch (ai_CommandID)
case 3: mySubMenu.RemoveItem(1); break;
mySubMenu.InsertString(4,3, "Remove previous item", "");
mydialog.Title = true;
