SetChecked Method
The SetChecked method sets the checked state of an item.
    SKMenu.SetChecked(commandID, bool)
    commandID UINT value that contains the command ID of the item.
    bool Boolean value that specifies the checked state.
    The following example creates a HTML dialog containing a menu with submenus, an item can be checked and unchecked.
       switch (ai_CommandID)
          case 1:
            alert(mySubMenu.GetChecked(1));
            break;
          case 3:
            mySubMenu.SetChecked(1, !mySubMenu.GetChecked(1));
            break;
    mySubMenu.InsertString(3,1, "Say if ckecked", "");
    mySubMenu.InsertString(4,3, "Check/Uncheck previous item", "");
    myMenu.InsertSubmenu(2,4, mySubMenu.Handle, "Menu", "");
    mydialog.Title = true;
